Use the following as a BASE LEVEL construction of an LFP bank, 12v, 24, whatever.
Read, and delve into other threads if you want to go down rabbit-holes of engineering. BUT, still - be safe. That means wrapping/taping your construction tools from handle to head. No wrings, watches etc. Basic battery safety should be followed.
We are making the assumption that you are building a bank that will draw no more than about 0.1C, maybe 0.2C on peaks for long-lasting solar autonomy. IN other words, your application is that of solar storage, with plenty of capacity, and not a high-current EV.
Because you are using the typical solar charge controller (with NO temperature-compensation active!), this means top-balance as shown below. Bottom balance is valid too, BUT only if you have the specialized circuitry to actually use it properly. But for practical charge-controller reasons, we'll stick to top-balance.
1) You purchased good quality prismatic cells from a reputable dealer. No used, old-stock, gray-market, crap.
2) You have access to a programmable bench-supply (and know how to safely use it), or a "single-cell" 3.2v nominal charger (upper limit usually 3.6v max), or a quality hobby charger like an iCharger, Revolectrics PL6 / PL8 and know how to use it.
2A) Hobby charger users: note that I'm NOT talking about using individual bleeder/balancer leads, but just setting your charger for a "1S" configuration, and charging each one individually, one by one.
3) INITIAL CHARGE: Charge each cell individually to 3.6v, until the current naturally tapers off to 0.025C. (ie, a 100ah cell should be stopped when absorb slows to 2.5A). Be mindful of polarity if your bank is already link-connected. No need to exceed 0.33C, but also don't do the initial charge at less than 0.1C for efficiency and the ability to reach 3.6v *in time* so as not to take all day to do so! As we know, sitting at full charge, or being near it all day long is not good for a cell's health.
4) Clean your terminal links if necessary with a non-wire brush. A plastic scrubber followed by a *thin* coat of aluminox, penetrox and the like should be applied between it and the terminals themselves underneath.
5). For normal charging, you can charge at a bank-level of anywhere from 3.45v to 3.6v per cell (ex: 13.8 to 14.4v for a 12v batt) with a CC/CV algo. For best results, do not charge in CC mode faster than 0.33C. Your battery bank will reach full charge anywhere from a CV of 3.45v to 3.6v, the only difference is that this absorb to full will take much longer at 3.45v per cell (0.025C again) than it will at 3.6v.
Don't want to charge to full? You choice: stop at a specific voltage. OR, stop somewhere before a full-absorb has been reached. Up to you. Many threads on this. You'll find out soon enough.
6) Preventative Maintenance: During charge, now that you have done the so-called "top balance" by charging them individually (and are not CRAP), you should see no cell lower than 3.45v, and no higher than 3.6v during the absorb phase. Ideally, you'll be much closer than that, typically no larger than 0.1V difference between cells. *at the end* of a full-charge. (again. 0.025C absorb current).
7) Use a quality voltmeter, not a shirt-pocket cheapie.
8) Set your LVD conservatively at the start to 3.1v per cell. If you want to go lower than that, you can, but generally no need at first - do not let any cell go lower than 2.75v.
8A) Option: Because we are not designing for a high-current EV, but drawing a piddly 0.1C or less, a "pack level" LVD can be used, especially if it is set conservatively at 3.1v per cell. Basically, because you purchased quality cells close in both capacity and internal resistance, AND because you are not trying to drive a high-current EV home, this may suffice because of our gift of time with a low-current application.
9) Just like taking care of a lead-acid bank, this means a little preventative maintenance from time to time. Every once in awhile, watch the individual cell charge voltages and as long as they are not 0.1V or more different from each other, you are good.
10) Notice I have not mentioned any use of bleeder / balancer boards. Because you did step 3 properly, there is no need as long as you didn't fall prey to junk prismatic cells.
It's that simple. Before going down other rabbit-holes, keep *our application* in mind. Most often, you'll find it straying into the inevitable comparisons to EV, Radio Control, racing, or even lithium battery chemistries that are not LiFeP04 (typically the 3.7v nominal, not our 3.2v nominal LFP).
These are the BASICS. If you want to throw a lot of gadgetry on top, be my guest. Just ask yourself if you trust a $2 little bleeder/balancer mosfet on your $2800 bank! Or do you have the skills to do step 3 properly, and look at step 9 once in awhile?
11) PRACTICE FIRST: unless you have a huge budget, try it out on a small 40-60ah 12v bank to prove it to yourself like I did, that this can be done. This will serve nicely as your auxiliary / learner bank. it would be irresponsible to tell someone to just follow these instructions and build some monster 48v / 2kw bank with no previous experience. We don't do that with lead-acid, and we shouldn't do that here.
