Do not be silly trapping yourself inside a box. You are right, commercial Lithium batteries have BMS, they have to because they are to damn fragile and do not tolerate any kind of abuse. Pb batteries can take all kinds of abuse and require no BMS.
Where you are trapped inside a box and being silly is you can buy a BMS for Pb batteries that can even add water if you are that lazy and ignorant. Case in point. If Lithium batteries were as good as you think they are, every telephone, cellular, data center, 911 Communications, public safety communications, and military systems would be using the. Care to guess why they all use Pb?
EV's, Cell Phones, Laptops, power tools, ect are an exception to the rule for a 2 very good reasons:
1. Specific Energy expressed as Wh/Kg or how much energy per unit of weight
2. Energy Density expressed as Wh/L or how much energy per unit of volume.
Neither of which are required for stationary applications, nor can be justified by the 400 to 800% long term cost that goes with it. Only EV's and other like applications can justify the cost and short term battery life.
To have equal amounts of usable energy; a Pb battery would have to be 4 to 6 time heavier, and 3 to 5 times larger in volume. That 900 pound Lithium battery in an EV would weigh 4000 pounds and as large as a car if Pb were used. If you know anything about physics you would know that would be impossible because it takes a whole lot more energy to move a 4000 pound dead weight than it does 900 pounds. That is why you do not see Lard Ass athletes setting running speed records. They cannot compete. When was the last time you seen a 250 pound Jockey in a horse race?
