I wrote:
and you replied:
I don't understand why you replied with this. Is it dangerous to discharge my pack to 10v in series, having bottom balanced? Why is the test procedure I outlined above not adequate to determine pack capacity?
I have zero interest in top balancing. I'll charge with my Midnite classic to 13.6v. Then I'll remove the battery and use the pl8 to discharge at a 10 amp rate to 10v, recording the ah draw. I'll then reinstall the battery, charge to 13.8v and repeat. Sound like a reasonable test?
