Charging efficiency LifePO4
  • dax
    • Oct 2015
    • 50
    #151
    I think understand it a little better. Thanks for the explanation.
    All I ask in return is that while you and some others may have found a better mouse trap to charging lifepo4 batteries the technology is still not widely known and may come under the microscope of doubt.
    Understanding that logic is also not rocket science.
    People that have technical experience are not easily swayed by advertising glitz and false promises. We need hard facts that help us understand what is being presented as being truthful. Until your technology becomes more mainstream and available you might have an uphill road convincing people to believe in it or even harder to purchase it.
    We have installed and sold over a hundred of our chargers here in Aus, NZ, PNG and Indonesia, there is also a really good lifepo4 solar charge controller now being produced in NZ, which is just like ours. The understandable problem is, it's very hard for people to get out of the lead acid mind set and look at lifepo4 from a very different perspective and the only way you can do that is be experimentation and real hands on use with big and small systems. We've spent many years working with these and it was only a couple of years ago we made the break from lead acid mentality to lifepo4, the results have been great and now we don't even need a cumbersome BMS. We use simple raspberry Pi's running linux to control our pack enclosure temperatures and to control outputs from individual banks in the pack, which again improve the performance of the system. In fact everything in our business runs on linux, which is 21st century technology and we get the same thing from those trapped in last century junk windows and apple. But they can't do what we can and like all fools, run our computer ans off grid systems down. Now we are getting solar and battery retailers inquiring about our systems and chargers. We don't even advertise, nor have a website, all our work comes from customer referral which is all the acceptance we need.
    Of course those programmed in the past century approach are extremely reluctant to change, our engineers had great trouble accepting my idea's for this and everyone I spoke to with qualifications said it wouldn't work. Once our engineers put a test one together and tried it for a few days, they changed their minds and now are refining and making it better by developing it so it charges individual cells.
    I'm lucky, not trapped in last century technology programming. so didn't find it hard to look at the situation and work out we needed something that just charged bulk inputs and stopped when it reached a set point. Then started bulk recharging at a point where it was not cycling.
    Lifpeo4 handles it easily, everyone with real knowledge agrees they can take big charges and don't like floating or other last century settings and we have proved that in our own workshop and the field. So we have not invented anything, just put together all the facts to make something that suits the situation. With just a small amount of research throughout the industry, you will find we have done what the technology needs, according to all the information and nothing special.
    • dax
      • Oct 2015
      • 50
      #152
      Sunking, do you really have to try so desperately to change the definition of floating a battery, a battery to float requires an input which compensates for the natural loss of a lead acid battery, not switching of charge and letting it sit. If you let a lead acid battery sit with no float charge, it will lose energy and is not floating, but naturally draining, float keeps it at its optimal charge.
      lIfepo4 is the opposite and has very negligible loses and they happen over years, not hours or days, If your lifepo4 pack uses the proper voltages, bulk charging, is balanced and within a controlled environment, it functions excellently. As for balancing, our method works and that's what counts. Personally couldn't give a stuff what others do, but 8 years of no failures and more than 2 years using our own charge controllers with not problems along with increasing installation bookings and sales, is all we need to know we are on the right track.
      Are you so desperate you have to demand what I post is something else, as in claiming our chargers charge to 14v, then slip back to charging at 13.6v. Surely you have just a little bit of a functioning brain to realise that is an absurdly stupid claim, nothing could be farther from the truth and it makes no sense. Our charge controllers, both solar and 240v are single stage, bulk and nothing else.
      You really are a great laugh, but sadly those reading these forums to try to get some idea of where solar and lifepo4 sits, will get confused as you contradict yourself and try to cover up you're never ending changes in definitions and absurd claims.
        Could not agree with you more. Does the same thing for lithium. Your is charged to 14.0 volts. When charged you lower voltage to 13.6 and Float your battery. That is what ever 2-Stage battery charger does. Every solar charge controller makes them that way. Better units have 3rd and 4th stages. All you got is a plane jane 2-stage charger.
        You have no clue what you are talking and each time you open your mouth you stick your foot in deeper and show everyone you have no idea how a battery charges. You are lost between a Marketing Term like Float Charger and a Technical term like Float Mode.
        How do you charge a battery?
        Very simple apply a Set voltage until the current tapers to 3 % of it C spec. Makes no difference if it is a lead acid battery or Lithium, they use the exact same voltage of 14.4 volts. When the current tapers you reduce voltage to maintain capacity and allows the charger to run the loads while the sun is shinning saving your batteries. You lower the voltage to 13.6 volts for either FLA or LFP. You do not have anything specials, just a 2-stage charger and you do not have a clue how it works or how any battery charges. You already admitted you do not know. If you cannot do and understand the math, you cannot understand the laws of physics.
          #154
          I would add that getting out of the FLA thinking also requires someone to compare the costs. Based on all existing data a Lifepo4 chemistry battery costs a lot more up front then quality FLA batteries. While your charger may allow the Li battery to get a longer life the final cost / kWh being generated by that battery is the final determination to go that way or another.
          Since both you and karrak are technically neighbors you both share the high cost and low reliability of grid power. So it is an easy sell for your area and the other areas you mention. But when it comes to most of the US and Canada going with any lithium battery would not be cost effective for a home owner. The POCO's might be able to afford those systems by not the average guy down the street.
          As for my thinking being old and "trapped" in the last century, that is something stated by people that have no understanding or patience of their parents generation. Making that type of statement does not win you any friends. I should know since I did the same when I was in my 20's but grew up and got to know my father's generation ideas so I could find ways to make technology better. I believe I have made a difference with my 40 plus years of electrical engineering experience but I choose not to brag about it.
          So I look forward to actually seeing your charging system hardware and how it works with lifepo4 batteries. I hope it is a breakthrough but again it still comes down to cost.
          • dax
            • Oct 2015
            • 50
            #155
            Just a couple of points, I'm 70 so not so young and have been a master builder since 20. Always had the philosophy if something new comes along and it looks good, will make an improvement if life, check it out with an open mind, that's how we got into lifepo4. It's the same with everything I do, have virtually no fuel bills as every vehicle, piece of machinery and modes of transport we have, runs on either electricity, or used veggie oil, which we collect for free. This reduces our costs, which we pass on to customers.
            You are right, we do have a high costing grid power, the last time I looked, the average grid bill in rural area's of Aus comes in at $400-$800 a quarter. So you could say a user will pay from $1600 up per year for power, if we balance it, that's over $2000 a year and we know of many who part out much more than that. Commercial interests, have bills over $1000 a quarter and in areas without power and just diesel generators, thousands a month.
            For an average home that is thrifty in energy use, you can have a 24v x 3kw panel system with 1000ah, 12v pack 240v output lifepo4 system installed and running for $7000, depending on location. Basing it on $400 a quarter, you get you money back within 5 years and still have 5 years of a warranted system left to enjoy. A remote system of over 10000ah lifepo4, taking over from diesel generation, gets you your money back within 2 years and sometimes sooner.
            I don't see our system as a break through, just common sense according to the facts. We use simple peltiers for controlling enclosure environments, controlled by cheap raspberry Pi's and will change that as soon as we have a better approach.
            By using linux we've constructed our own custom OS, in fact we have 3 for different things and all are totally compatible and play with the servers very nicely. No proprietary, support or upgrade costs and all our work software is what we have developed and this has saved us thousands a year. It's how you approach things which make the difference and how willing you are to experiment. There are many times when lots of knowledge can make you blind to the evolving reality of a technology, lifepo4 seems one most electrical engineers can't seem to broach.
            As we've been installing off grid since 1981, know the economic difference when comparing off grid lead acid systems to lifepo4 systems and lifepo4 wins hands down by many years. No one can offer a 10 year guarantee for a lead acid system, but we bit the bullet and did it with lifepo4, because we know they will make it well beyond that. Our first lifepo4 installations have 3 years warranty to go and none have ever complained or had a problem of any significance, that speaks for itself.
            • dax
              • Oct 2015
              • 50
              #156
              Hilarious, can't read, blind to fact and determined to be right not matter the cost to your credibility and rationale, when everything categorically states you are wrong, wrong, wrong. Once again you have changed you stance because you made such a ridiculous statement that float is when you disconnect the battery at full charge.
              Not going to post your comments, anyone can see what you post and the number of times you make insane claims, then have to change them in an effort to cover your tracks. That's what blind ideological people do, claim one thing, then when reality looks them in the face, they change tack, deny and lie, to try to save face and support their unsupportable fantasies.
              We use our own designed and manufactured single stage lifepo4 chargers. I repeat single stage, bulk single stage. Note, bulk single stage chargers.
              They are called single stage bulk solar chargers, which supply just one stage, called bulk and nothing else. in case you didn't get it, they shut down completely when the bank or pack reaches 14v. They restart charging when the pack voltage drops to 13.6 volts and shuts down completely when it again reaches 14v, load comes from the pack, not the panels. Would you like me to repeat that again, single stage bulk charge controllers, not 2-3-4 or 5 stage, single one stage and nothing more.
                #157
                Sounds like you have had many opportunities to experiment with new ideas. I unfortunately did not have that based on living in a highly populated area were making my own fuel would have been frowned on. Still I was able to try out some new things and found ways to reduce my electric bills through conservation and more efficient type of loads.
                As always I look forward to seeing new technology that makes it to market and becomes a cost effective product for people like me that is not in the top 1% that can throw money at every little thing.
                When it comes time for a battery system I will be happy to look at what your company can provide and make a decision if it is something I would financially benefit from it's purchase.
                  I assume your charger actually has two stages - a constant current phase (often called bulk) and a constant voltage phase (often called absorb.) These often do not seem like two-stage chargers because you don't have to do anything to get them to switch over; it happens automatically as the charger comes out of current limit.
                  You can charge a battery with a single stage charger, but you will then either have to choose a slow charge rate with the battery getting close to full, or a fast charge rate with the battery being only partially charged when the charge is terminated. That's why most people use two-stage.
                    Jeff he is to ignorant and has no clue what he is talking about. He has proved it over and over again he has no idea how a battery charges or how battery chargers work. He has no idea he uses a Float Charger and charges exactly like you would any battery.
                    He is so ignorant he has no clue he charges exactly how I am telling Ceatethis to do it. Float the battery.
                      You really are ignorant. Not only can you not do simple 5th grade math, you know nothing about electricity
                      You do not even grab or understand the most basic fundamentals of electrical laws and physics ity. One such fundamental, th every first one you must learn by heart is Ohm's Law. If you knew what it was you would know if there is no current there is no power. Simple Ohm's Law a 5th grader understands is Power = Voltage x Current. It means one of two things. You are either a 70 year old Ignorant SOB or a Fraud.Which is it?
                      You came here looking for trouble and you found it.
                        It is not two-stages, just a simple 1-stage CC/CV Charger aka Float, Equalize, Bulk/Absorb, Maintainer or plain ole Battery Charger
                        2-Stage is two Voltage Set Point like Float and EQ, or Bulk/Absorb and Float.
                        3-Stage is 3 Voltage Set Points like Bulk/Absorb, Float, and EQ
                        Some LiFePo4 chargers have what they call 5 stages like this one from Battery Tender. Step 1 is Recovery Stage if the battery voltage is below 2.5 vpc. Applies a low current level to recover cell to 3 volts for up to 4 hours. Step 2, 3, and 4 as you can see on the graph are really one stage of Bulk/Absorb/Float as it holds 3.6 volts on the cells until current tapers to .1 amps. Then stage 5 is Float at 3.45 volts to hold the charge and run equipment.
                        What I am saying here Jeff is all battery chargers are CC/CV. Stages are voltage Set Points. Take any DC power Supply with a Current Limit, and you have a CC/CV battery charger. 1-Stage is required to charge any lithium battery. a 10 amp 12 volt battery charger will charge any battery type assuming you set the voltage correctly. For a 4S LiFeP04 is 14.4 volts. Apply 14.4 volts until current tapers and you are charged up. Exactly the same you would do for any Pb battery, same charger, same voltage.
                        A good 2-stage Lithium charger is one used for Solar, any of them that allows you to set the Bulk/Absorb, and Float, EQ disabled. Set Bulk/Absorb to 14.4 volts, and Float to 13.6 volts. Battery charges up to 14.4 volts 100%SOC, and reduce voltage to 13.6 volts so the battery stops charging and floats at 13.6 volts waiting for the sun to set. In the meantime while the Sun is out, the panels provide the power so you can save the batteries for after the Sun Sets. Kind of the whole point.
                        As for me I am a simple KISS engineer. and only use one stage for Lithium Charge to 13.4 to 13.7 volts, Hold and Float the battery the cells will saturate to about 90% SOC (why I give a range 13.4 to 13.7). Does the same thing a bit slower, less expensive/complicated and less voltage stress on the cells.
                        Now if you want to see the Caddilac of Battery Chargers Elcon HF PFC chargers are it. I use the PFC 1500 which means 1500 watts which can charge any battery type from 24 to 240 volts with as many and any algorithms you want. Just make your list of Profiles and order it. I have 4 Profiles in mine. Lithium is easy
                        • dax
                          • Oct 2015
                          • 50
                          #162
                          No it's a single stage charger, bulk charge to 14v then switches off, there is no more input into the pack until the pack drops to 13.6v. It seems none here have got past the lead acid syndrome, lifepo4 will take bulk charge until they reach capacity, there is no need for slow charge rates unlike li-ion or lead acid. Lifepo4 don't heat up, or offer big resistances to input when taking big charges.
                          Look at at this way, the pack reaches 14v or a cell reaches 3.5v, charge is disconnected, panel energy is directed to other sources. When the pack drops to 13.6v, charging is redirected to the pack until it reaches 14v then the sequence starts again. That's it, nothing else as we are using lifepo4, not li-ion or lead acid and lifepo4 perform and take charge very differently to other lithium chemistries and nothing like a lead acid.
                          These chargers have been working excellently for years now and anyone watching them in operation, can see and test there is no slow down in charge input up to 14v just bulk, then no charge enters the pack. The voltage of the pack controls the charge regime, not current. This is the 21st century, not the 19th, we are in a different energy storing era, it's not lead acid and every argument put forward here against this revolves around lead acid mentality and not 21st century lifepo4.
                          Got nothing more to say on this, no good talking to brick walls.
                            It is not two-stages. . . .
                            Constant current - bulk - first stage
                            Constant voltage - absorb - second stage
                            That's why a three stage charger really only has two voltage settings - absorb and float. The third stage is the current limit that occurs during bulk charging.
                            • karrak
                              • 528
                              #164
                              Can't do this unless you have top balanced the battery and/or have individual cell monitoring.
                              This works great for all chargers except chargers using solar as the power source. I use exactly this charging method to charge my electric bicycle batteries.
                              When I first installed my LFP battery I had drunk the Kool-Aid and decided to only charge my battery to 90% and not float charge to maximise the battery life. This meant charging it with a cell voltage of 3.375Volts/cell (13.5 Volts). The problem with this approach is that the battery started going into Absorb at an SOC of around 75% and would take forever to get up to 90+% and there is only so much sunlight in each day.
                              After doing more research and getting information from others who are using LFP batteries on other forums I have come to the conclusion that charging to 3.45 V/cell (13.8V) will not make much difference to the battery life compared to charging to 3.375 V/cell(13.5V) and will mean I have a battery >99% full at the end of the day.
                              Simon
                                That is why I qualified it with 100% SOC.
                                When I first installed my LFP battery I had drunk the Kool-Aid and decided to only charge my battery to 90% and not float charge to maximise the battery life. This meant charging it with a cell voltage of 3.375Volts/cell (13.5 Volts). The problem with this approach is that the battery started going into Absorb at an SOC of around 75% and would take forever to get up to 90+% and there is only so much sunlight in each day.[/QUOTE]Simon I don't have a problem with that. I have been telling Createthis the whole time he has to find the right voltage for him.
                                It is DAx who thinks he is doing something different and magical, when in fact he is just using a simple Two Stage Charger. and is FLOATING his battery. He does not have the capacity to understand.
