I'm looking at putting together a small test setup with a 40ah GBS heavily influenced by PNJunction's generous online contributions.
I have not seen mention of this charge controller, whose manual indicates an option for Li-Ion mode upon a selection and setting adjustable float charge (13.8V to 27.6V). I will be using as a 12V system and anticipate charging to 13.9 volts across the 4 cells.
I have been trying to figure out if temperature compensation indicated in the manual and charge method are truly compatible, with this being indicated on Amazon to be two stage charging. Additionally, I'm unsure if float voltage needs to be lower than bulk setting (and absorb/equalize I guess) to treat the battery gently and to minimize cell voltage drift. Battery will be charged with two paralleled 100W 12v nominal PV panels for at total of around 12A, so modest charge rate if that makes a difference.
On a side note, I plan to either use the load port of this controller with LVD at 12.8V (adjustable 10.7 to 21.4), or employ a Xantrex C35 with adjustable LVD for higher discharge rate capabilities.
So I reached out to the manufacturer and got the following responses that weren't excessively helpful for me:
"Is the temperature compensation disabled in Lithium Battery mode? No, it`s ok for all type of batteries.
Is the float voltage applied continually in the lithium mode? Yes, you need to setup the float voltage and set the controller for lion battery.
Can you explain how the charge cycle works in lithium mode? It`s a PWM controller, the charge mode is boost-equalizer-float."
My impression is that temperature compensation is a CC electronics compensation and not a charge value compensation like would be expected for lead acid (I don't see that the CC has a temp probe input to use). The last answer seems like it might be three stages of charging, but I am not sure if boost=bulk and equalize=absorb.
What say you on whether Is this a decent cost effective option for (bottom balance) PWM charging or a product whose "lithium mode" is not compatible with PNJunction style (conservative charge and discharge stop points, no BMS as I understand) Li-Ion care?
Thanks much.
Thanks much.
