Hello,
I'm working on designing an off-grid home and would like to consider the option of going with a LFP battery in the range of 20-30kwh. I like the idea of have a low maintenance battery without the need for ventilation.
From reading through the forums, there seems to be a lot of concerns around the failed Chinese based LFP batteries that flooded the market and ended up getting rebranded under new company names.
I've done a lot of research and found a company called "Simpliphi Power" and they seem to have an attractve product with a built in BMS, 5k cycles, and 10 year warranty. The company has a 3.4kwh "smart-tech" battery that allows for you to scale up the size of the bank in a module fashion.
http://live.simpliphipower.com/wp-co...spec-sheet.pdf
Has anyone worked with this company? I can't find any references in this forum. From my research it seems they started selling portable power back for mobile video equipment 10 years ago and transitioned into higher power stuff, including military.
A recent google news search says they've passed some tough military tests on some of their portable power packs - so that means they are at least living up to their performance specs.
The product claims it can work with traditional off-the-shelf charger controllers designed for lead acid batteries, so this seems attractive as well.
I found the installation manual for the product on a reseller website for those interested in reading about the specs and warranty.
http://dpasolar.com.au/media/mconnec...warranty_2.pdf
Any feedback on this company or product is apprehiated. (Being new here, but having read through the forms a lot, I'm assuming Sunking will chime in soon!)
