Thanks for sharing, it's the only way we will learn. Successes and Failures will help us all understand where we need to go.
I know you removed the boards and thats ok. A couple tips for those using them, there are two issues that can arise when you install them that people should be aware of. Yours were connected correctly. Cell #13 it's hard to tell, I wonder if it did hit the balance voltage at some point ?? I did test mine with a bench top supply and numbered them.
1) They are piggybacked on to the connecting terminal, meaning the interconnect / cable goes on to the battery terminal first and the board connectors are last closest to the bolt / nut and below the washer.
2) When you make the last connection to the battery bank make sure the output cable is cut off to the bank and load. If you do not have a breaker disconnect the board can end up carrying the whole load. It will fry the board or damage it. A fused disconnect will not work and the inverter will begin to boot as soon as the last connection is made.
