Solar charge controller, what for?
  • PNjunction
    Originally posted by bungawalbyn
    All my sensors etc will be on the battery side, so the voltage drop shouldn't affect any thing in the controls. Opinion?
    I'm not the guy to ask that from since I don't have a roof install. However, I can say up front that your homeowners insurance needs to cover your DIY install, or a roof fire may leave you penniless and not covered from a professional licensed installation. Just don't want you finding out the hard way.
    I've got a 400A T class fuse on the way for the battery. This should cover everything running at once with some margin.
    MUCH better than a stereo fuse for sure! Check with the big boys on that, like MaineSail and others here. Remember I'm only running a 40ah battery max!
    They are still a way above nominal, and if they keep giving like they are, there are MANY hours of useful power. Provided I can keep them from an early death, I think I'm going to be a happy camper.
    I don't know exactly what your monitoring is, and how much current you are actually pulling, but just know that around 3.195v / cell *rested* is about 80% DOD. Since you have a lot of capacity to play with, I'd just stop when the first cell just starts to dive under 3.2v, or perhaps when it hits 12.75v pack total.
    BUT this is the most important charge / discharge to watch like a hawk for infant mortality. Grab a non-alcoholic beverage, non-conductive chair, and a Fluke multimeter and WATCH to see if any cell is trying to take a dive.
    Note that while lifepo4 doesn't really need a break-in, for the first 2 cycles or so, the SEI layer is settling down to a normal depth. So don't be surprised if there are small differences until you get a few cycles in.
  • bungawalbyn
    Thanks PNJ for the technical explanation.
    I've noticed that often in forums, threads degenerate into acrimonious argument over minor side issues. Hopefully we can avoid that here.
    A little question, I have a 400A (2X200A) Shottky diode in the parts box that I was thinking might be a good idea to put on the solar input line to add extra protection for the panels and to stop any problems should I have a fault in the wiring up on the roof. It's the place where I am most likely to have them. (wind rain condensation etc). All my sensors etc will be on the battery side, so the voltage drop shouldn't affect any thing in the controls. Opinion?
    An interesting observation. In my efforts to reduce the voltage from the balance charge, I've used the bank to run the house for 2 nights now. The second night caused little drop in voltage over the previous at rest. Like about .02V with bank at 13.21 to 13.25 at rest, Depending on day/night temps. All Cells holding at 3.31V This suggests I have them down on the flat now.
  • PNjunction
    Originally posted by karrak
    I am interested to know what the mechanisms that degrade LFP batteries are and how they can be avoided, I suppose this is the million dollar question that everyone would like the answer too.
    It has to do with electrolyte contamination from parasitic reactions at both the top and bottom ends of charge when the anodes and cathodes can no longer support any additional intercolation, ie passing of lithium ions from one side to the other.
    Too high a voltage, held for too long a time produces oxidizing materials to contaminate the electrolyte.
    Too low a voltage, and the copper, aluminum, and other parasitic products are pulled from the anodes and cathodes into the electrolyte.
    The double whammy at the low end of charge, is not only is the structure of the battery being eaten away, and the sei layer contaminated, but dendrites form given enough time, which is why you need to get on top of it asap. The double whammy part is applying a full charge rate at very low soc's, where not only are you dealing with a corroded internal structure, but also the contaminated electrolyte from inorganic pollutants. A full charge current here is dangerous and uneven. Basically at full charge current (less than .01C recommended at very low soc's), there is a traffic-jam of ions not being able to pass through the sei layer fast enough with nowhere to go.
    Basically we want to protect the SEI layer from inorganic contaminants. If it weren't for that, the cells would be immortal.
    The natural protectant of the SEI layer grows on it's own under the best of conditions. Parasitic non-organic compounds added to that from extremes of heat / charge / usage don't help.
    Note that this is slightly different from the organic compounds usually put into the electrolyte on purpose for *normal* cycling. One of the major players here is vinylene carbonate, without which the cells have a very short cycling life. All the manufacturers include this, but add their own additional compounds for different technical results - high heat, ease of manufacturing, charge rate, etc.
    This is why statistically it is best to be conservative and run 80-10% DOD or *less*. The further you run away from the top and bottom of charge, the slower the contamination will be (so far it has proven impossible to stop completely). Of course the tradeoff here is your overall desired operational capacity, and of course cost of using larger capacity cells to stay away from extremes.
    The quest is to keep your application TIME in mind. For example, EVEN at say a conservative voltage of 3.5v per cell (14v for a 4S / 12v setup), the cells will eventually charge to 100% SOC and there will no longer be any lithium to intercolate. Of course lifepo4 has a very short absorb compared to lead, but it will eventuallly fully charge. Now comes oxidation time.
    Those who routinely cycle their batteries may not see the oxidation effects at nearly full charges because they aren't held there long enough for absorb to finish. But for those who want to float, 3.5v would be disastrous overall and *eventually* oxidize once absorb is over - simply because they've been given enough time to do so and pass into the parasitic reaction stage of oxidation.
  • PNjunction
    Anyway, this thread wasn't started to argue the pros and cons of FLA. Lets not get hung up on distractions
    Heh - rule #1. Do not even mention FLA or other battery comparisons for purely technical threads about lifepo4. It is a guaranteed thread-killer with too high of a signal to noise ratio. Keep that for other dedicated comparison threads.
    Balancing. Rule #2 for thread killers. Pick top or bottom and deal. In your case, try them both (not at the same time) and see which one fits your operating environment best. There is no shame switching from doing it one way to the other. They are your cells.
    Part of what makes a sensible discussion about lifepo4 difficult, is that they can fulfill a variety of different needs, and each application (EV / RC / sub-c solar etc) benefits from a variety of techniques. Some techniques may not be the absolute best technically, but can work in the real world if one is knowledgeable enough to deal with it.
    There are tradeoffs in everything, and this is where most of the trouble begins.
  • bungawalbyn
    It never was "Gold" it was only ever lead. It's crap, always has been. Only reason it's a standard at all is because there has been nothing better, doesn't stop them being crap, hopefully LFP or something even better will gain acceptance and replace it in the near future.
    I don't know why you're so defensive of them when you listed their faults and chose LFP. What's that about?
  • Living Large
    The Tesla power wall and the like could well change all that.
    You don't seem to be understanding my point, so I will spell it out.
    You appeared to question if FLA is the current gold standard. If FLA isn't the current gold standard, what is? Not tomorrow, not a year from now. What has been adopted, and is the most widely used plug and play battery technology for solar system use?
  • bungawalbyn
    Originally posted by Living Large
    As of today, FLA is the gold standard. I could tick off all the negatives I found with FLA as well, which made me willing to take a chance on LFP. Does that make LFP the new gold standard? The new standard? Hardly - there is nothing standard about using LFP in a solar system today. Obviously I am willing to try LFP. That doesn't mean I am ignoring the fact that is an expensive experiment today. Tomorrow? Who knows.
  • karrak
    Correct. Last thing you want to do is Float a lithium battery at 100% SOC. But absolutely no problem at 90% or less. FLA batteries start sulfating at anything less than 100%, thus why you want to keep them fully charged at all times. Scaling in Lithium batteries start at 90% SOC and and accelerates from there up to 100%.
    I also think that what voltage/SOC to float an LFP battery is a key issue to longevity.
    I am interested to know what the mechanisms that degrade LFP batteries are and how they can be avoided, I suppose this is the million dollar question that everyone would like the answer too. Sunking, you say that "Scaling" is the problem, but this only occurs with an SOC above 90%, could you give us more information on what "Scaling" is and why it only occurs above 90%SOC.
    Simon
  • Living Large
    Was that Gold standard or Old standard?
    If LiFePO4's live up to the claims, and the industry produces specific control gear to suit, then sooner or later, FLA will take it's place alongside the steam engine. Add to that the toxicity of FLA and lead in general, I say good riddance.
  • bungawalbyn
    OK, now we are singing from the same sheet on "float" let me run this idea past you.
    To use excess charge, slightly before batteries hit the predetermined cut off voltage, 80ish% SOC, I was planning on having another voltage sensor to operate a 1000w HWS element, which is a close match, taking into account efficiency loses etc, to the maximum output of my panels. I'd keep the hi lo points on this tighter than the main charge control sensor, so it acts as a "float" controller.
    I have a plan b on this which is to allow the batteries to hit cut off and divert the power direct to a 12V element. My cut of relay is a 120Amp SPDT I sourced so I have the option of load dumping/diversion. The other is the preferred option as cutting charge at full bore I would imagine is a bit rough on the relay contacts, + wire length to HWS and I'd have to find a suitable 12V element.
    Hi Sunking,
    I think I see where we may be having a disconnect on "Float".
    I agree.
    I guess what people are referring to with float being BAD is holding them higher than 100% SOC voltage. ???
    In a Solar system or any system that is cycled daily needs to get to Float ASAP so you are not using battery power, or at least minimize battery power during the day. However with Lithium Float is NOT 100% SOC, something less like 80 to 90%.
  • bungawalbyn
    Hi Sunking,
    I think I see where we may be having a disconnect on "Float". I reread you post on this thread, which seemed at odds to things I've read by you on other threads, and noticed that for this you use a lower voltage than 100%SOC, where "float" would be used to top up for usage, but not add to charge. Whereas for FLA float is set at higher voltages so that it continues to trickle in charge to work the slow chemistry and compensate for self discharge
    My BMS is monitor and trip protection contactors only, no balancing. And I did consider, and still have inverter Lo volt protection, but it's a bit low for my liking, it seems once you get down to that sort of voltage you are in the "knee" and voltage is crashing. While the inverter switches off the main load, it doesn't account for secondaries like meters etc, or for single cells dropping below safe levels.
    Bottom Balance eliminates all that BS.
    God, every one else with experience says float is death.
    OK then everyone you know is an Idiot. I am a professional engineer for 35 years working with batteries my whole career. I work with all battery types. Even set on IEEE Battery committee and we write the battery standards for professionals and engineers world wide.
    FWIW every utility, military, and professional communications use Float Charging because it is the best, kindest, and gentlest charging algorithm there is known to man. Every EV manufacture uses Float Charging of their Lithium batteries. All commercial Lithium chargers use Float. So you and the people you know are badly misinformed. With the right FLA battery, pure lead, 30 to 50 years on float service. No lithium or any other kind of battery can do that except FLA and NiFe can do that.
    Also lithium is far from non toxic and poses a much greater health concern than lead. Lets not even talk about the nasty chemicals required to make lithium. It is just not published and talked about to keep you the public in the dark like a mushroom. Keep the public in the dark and fed BS produces a very nice crop.
  • bungawalbyn
    Well every battery has pro and cons. At the end of the day, FLA is still the default winners choice once you consider all the pros and cons. FLA's are less expensive and last longer.
    When you relate real world FLA usage to manufacturers specs and claims, it's mostly con. Less expensive up front, granted, over life of batteries, that remains to be seen. The real winner for me was the ability to take all the amps I can throw at them to reduce charge TIME. + no/low toxicity.
    OK you have a lot to learn. As of now you do not even know how solar works. You can as you say not use controller, and just use the old fashion antiquated relay to connect/disconnect panels. Do that and you change your 100 watt, 18 volt, 5.3 amp panel into a 67 watt panel. Solar Panels are current sources and Battery Current = Panel Current of 5.3 amps. Use a modern MPPT controller and you get a full 100 watts as it boost the 5.5 amps to 8.3 amps
    In sub optimal conditions MPPT appears to give more charge, But are you suggesting that even in full sun, it will Magically give 50% more power? How does that work?
    You can Float Charge LFP, and is the best way especially with a solar system. All commercial LFP chargers are simple Float Chargers. There are no stages like Bulk, Absorb, and Float. Trick is you set the voltage to less than 100% SOC around the 90% SOC range. For a 4S LFP we are talking 14.2 For example let's say around 2 in the afternoon, the LFP battery tops out at 14.2 volts so charging stops. However you can now use panel power instead of battery power assuming the load is equal to or less than what the panels can supply. That takes some of the load off the batteries and extend their life. You only use battery power at night or when power demands are more than the panel can supply.
    What is your system?
    How long have you been running it this way?.
    When using power from a system that is charging, your load takes 1st preference, it doesn't go into and out of the batteries, but straight to load (line of least resistance), leaving the batteries to take up excess or top up any deficit.
    As for using a BMS or HV or LV disconnects is not needed, especially in a solar system. You can use them if you wish, but there is no reason to use them. In fact us DIY EV builders would never use a BMS as they cause way more problems and battery destruction. The best and easiest way is to initially Bottom Balance your LFP pack, set charge controller to 14.2 volts, and let the Inverter LVD protect over discharging the batteries, then use your Inverters LVD to protect the batteries from over discharge. A 12 volt Inverter made for lead acid batteries has a LVD of 10.5 volts. LFP needs a cut-off of 10 volts so the Inverter LVD is more than adequate and will shut down when the LFP batteries reach about 10% SOC.
