New battery systems
Hey everyone, I have been reading your post about these alternative battery systems.
There is another option that you must consider - Nickel Iron.
If you take into consideration the future replacement costs of any other battery system, then paying a little more up front is really worth it.
its a sad fact but Sunking is correct.. For most people that use batteries off grid its not a matter of of choice its a matter of necessity.
ie I and some others use off grid lighting in Philippines for the simple fact we get (brownouts) or more correctly of course called blackouts at least once every 2 weeks ranging from hours to many days. The security of having lights is priceless.Leave a comment:
Affordable i would say more in the ways of cost over its dorasion in its life & not so exspencive it out ways getting connected to the grid & paying for it for the next 10 - 15 years the costing wise gwl power ive allready been speaking with comes out very Affordable thanks.Leave a comment:
LIVERSLEY an afordable low mantanece battery bank id like to hear any sergestions? Its not an easy question to answer .. Affordable? it depends as to how you determine that.. Affordable up front?? Affordable over many years??? Standard lead acid deep cycle batteries (12v)are the lowest cost,2v cells of high ahr are far more expensive and need regular maintainance and equalizing,(not easy with solar chargers) but if good quality like Surrette will have long life if very carefully maintained. Lithium ion phosphate batteries have the potential to have very long life if used in a solar energy setup. but have very high initial cost.. but no maintainanceLeave a comment:
thanks it was a good detailed awnser
yeah he did awnser my question after disifaling it all outi just wanted a simple way of working it out ie will 320ah of the LifePO4 batteries at 48v last as many or more hours of run time as my 320ah yuasu en160-6 battery bank at 48v? thats the simple question im looking for really? sorry i like things simple but i am disslexic as you may noticed from my spelling? any way after looking into it a bit it seems the batteries ive got all ready are quit good but i cant help thinking 1 day they will start to age before that happens like every one off grid i would like to look into a replacement battery bank? so if any one can sergest an afordable low mantanece battery bank id like to hear any sergestions?
Livesley im sure the Reply given by DELTAFOX25 has answered your question in it somewhere.
I cant give you the answer you were looking for as that figure as you noted is usually never quoted The only figure quoted is Max Discharge <3c
Why do you need that figure ? to calculate what?Leave a comment:
The LiFePO4 battery uses a lithium-ion-derived chemistry and shares many of its advantages and disadvantages with other lithium ion battery chemistries.
However, one key advantage over other lithium-ion batteries is the superior thermal and chemical stability, which provides better safety characteristics than lithium-ion batteries with other cathode materials.[6] Due to significantly stronger bonds between the oxygen atoms in the phosphate (compared to the cobalt), oxygen is not readily released, and as a result, lithium iron phosphate cells are virtually incombustable in the event of mishandling during charge or discharge, and can handle high temperatures without decomposing.[6]
Lithium Iron Phosphate chemistry also offers a longer cycle life over standard lithium ion cells.[6]
The use of phosphates also reduces the cost, safety and environmental concerns of Cobalt cells, particularly in regards of cobalt entering the environment through improper disposal.[6]
One of the other major advantages for LiFePO4 when compared with LiCoO2 is higher current or peak-power rating.[7]
LFP batteries have some drawbacks:
The energy density (energy/volume) of a new LFP battery is somewhat lower than that of a new LiCoO2 battery. (14% reduction in energy density) Battery manufacturers across the world are currently working to find ways to maximize the energy storage performance and reduce size & weight.[8]
Many brands of LFP's have a low discharge rate compared with lead-acid or LiCoO2. Since discharge rate is a percentage of battery capacity this can be overcome by using a larger battery (more ampLeave a comment:
thanks russ yes it is a projeck & a half but more of a nercesity i would say! its easy to see why people get anoudon these sites there is alot off diffrent appinions on here. has no one herd of dont baleave every thing you read
any way after looking into my 6v 160 en yausa batteries there 160ah at 10hr rate thats good is it not?
& does any one no the hour rate on these 3.2 400hr LiFePO4 lithium batteries cant find it any where??Leave a comment:
Hi Livesly - Welcome to Solar Panel Talk!
Quite a project!
RussLeave a comment:
LiFePO4 batteries
im also thinking of going down the route of LiFePO4 batteries?
at the moment im running 16x 6v yuasa160en giving 2 banks of 48v (which i dont think is enough) run through tristar controllers we have a 1x2000w 12meter windturbine non gied wire that runs through a tristar-60 pwm charge controller & 12x80w solar panels but at the moment there facing west on my car port they will be shortly going up on a solar tracker system which ive yet to build this will be going through a tristar-60 mppt charge controller (on order) running all are led 240v lighting 70w hole house, tv amazing samsung 21" led monitor hocked upto hd box 25w, standerd fridge freezer 150w kick in, intrernet pc 20w, 265w day to day runs off a studer 400watt inverter & all the bigger stuff washing machine, wellwater pump etc, runs off an old ups inverter charger 3750w which has 2 massive coils in it great for big stuff at full capacity but draws to much to just leave it ticking over so its just turned on when we need it & use it with a 6kva lister diesel generator for back up an charging. cost so far on evrythingLeave a comment:
Hi plateauhops, Welcome to Solar Panel Talk!
You can learn along with the rest of us! Most of us have a lot more to learn than Mike & Sunking but everyone should learn something everyday!
I admit it is easier for me as I have so much to learn!Leave a comment:
this is very cool
Just joined this thread. I am interested in BMS myself. Am looking for a solar setup with around 2kwh+ storage. Will be following this thread.Leave a comment:
