Hello, sorry if this first question is annoyingly basic, let's say I have a 48V 100ah LiFePO4. Is that battery's energy capacity just as good as a 24V 200ah LiFePO4 and a 12V 400ah...3V 1,600ah, etc?
Now I've been reading thru some of this forum and I forget where I read it but someone said it is very recommended to wire 24 3V 1,000ah batteries in series for a 48V set up, yet not recommended to wire a bunch of batteries in parallel. Why? As far as I knew that was the beauty of wiring batteries together, that you could mix and match any combo, like for instance put 2 sets of 6 in series and then put those 2 sets in parallel, etc. Where does the danger in over paralleling lie?
Is there a certain rule of thumb as to when you are using too many parallel connections for a given number of batteries? Like let's say you have 32 LiFePO4s for instance, obviously 32 series is ok and 32 in parallel is looked down on...what about 2 sets of 16 in series and then those 2 sets in parallel? Or how about 4 sets of 4 in series and then those 4 sets wired in parallel is that ok or is that bad? I'm just trying to figure out my configuration based on the best deals I can find on different LiFePO4 batteries, it's not that I'm being argumentative.
EDIT...I am actually right now looking at these 3V 180ah Calbs. I'm wondering if it is ok if I bought 16 and wired 4 sets of 4 in series, and then wired each of the 4 sets in parallel, for 12V and 720ah
