I'm thinking of putting together a small LFP boost battery pack. I will be able to use it initially to help extend the life of my expiring lead acid battery that I currently have (one string is on it's way out). That way I could limp through yet another winter on the 2 remaining strings. Eventually, when I replace my storage with an AHI battery pack, it will be useful in extending the usable storage of the battery when heavier loads come on.
LFP is well suited for handling high power applications efficiently, whereas AHI should give me plenty of long term storage, that will allow me to save on battery expense in the long run. The small LFP pack will improve the efficiency of the AHI pack, help extend it's usable life, and allow for a deeper discharge, which helps to minimize generator run time. It should be able to extend the useful DOD of the AHI bank from about 50%, to as much as 80% if need be.
I'm thinking of using an mppt charge controller to do double duty. One is to separately charge the LFP battery. The other is to send power to the AHI battery when requested (ie when the main battery voltage drops below a preset level in combination with a load detected). I'm thinking one or two extra cells should be enough to raise the voltage high enough for the charge transferring. And if one of the LFP cells fail for whatever reason, it won't be a disaster in which I lose my whole battery pack.
I do plan to operate the LFP within a safe range, so I actually don't expect to have a premature failure.
The other option would be to use dedicated PWM charge controllers, but not sure if there's units out there where one could limit current flow to preset levels (for the charge transfer)? Thoughts about the best way to go about this technically?
I do plan to operate the LFP within a safe range, so I actually don't expect to have a premature failure.The other option would be to use dedicated PWM charge controllers, but not sure if there's units out there where one could limit current flow to preset levels (for the charge transfer)? Thoughts about the best way to go about this technically?
