LOL. You do not call $400 plus support hardware expensive. Good luck convincing anyone.
Tom it is real easy to know if you have drift, and even easier to fix if it should ever occur. Once you get down to 10% SOC all th evoltages are equal. If not you have had drift. I have never seen any drift in 6 months of operation. I also know of about 136 EV's made by Jack Rickard, all Bottom Balanced and in operation from recent to 4 years ago and no drift.
If they do, we all have a very simple RC Hobby chargers to fix any battery problems. Most use a Powerlab 8. They will charge/discharge, balance, measure any characteristic you can name of battery of today and tomorrow. Rated at 1200 watts max. Just drive until you get near the bottom, then clip it on a cell, set to discharge to whatever voltage you want at any current you want within its limit. On a single cell can go to 30 amps charge or discharge. If you want to Top Balance it will do that with computer accuracy up to 8 cells.
