Not even a remote snowball chance in hell's it will work. You do not even have a down payment made yet.
First problem is you do not have 10 or 13 sun hours. No place on earth has that much sun. In the Bahamas for an off-grid system you have 4.5 Sun Hours in winter is the number we have to work with.
Second problem, and it is a huge very expensive problem, is you are a huge energy hog when it comes to off grid demanding:
Washer 1150 (2hrs maximums a day) = 2300 wh
Fridge 840 (intermittent all day) = 2500 wh assuming 33% run time
Television 240 (5hrs continuos) = 1200 wh
A/C 2300 (10hrs continuos) 23,000 wh
Total = 27,812 wh/day.
In your location that will require:
Panel Wattage = 10,000 watts, you only have 800.
MPPT CHARGE CONTROLLER = 2 units of 80 amp operating at 48 volt battery. You only have a single 40 amp controller.
48 volt Battery Capacity = 2800 AH or 7500 pounds worth. You only have 250 AH @ 48 volts and 600 pounds worth
Generator 10 Kw you do not have.
48 volt, 200 amp AC charger for generator you do not have.
500 to 1100 gallon LPG tank or 200 to 400 gallon diesel tank for generator you do not have.
With what you have can run the fridge or washer, but not both. Or you could run the TV for 10 hours. Take your pick.
