Floating an AGM battery
  • AzRoute66
    • Jul 2017
    • 446
    I keep a 12V 35 Ah AGM battery in the garage for various infrequent and brief projects. With my last battery I just left it on a Harbor Freight Cen-Tech cheapo float/maintainer box and that seemed to work pretty well, but I wonder if I might get improved life if I just put it on the charge for a day or two at a time. In other words, would I be better off if I only connected it for a couple days when the voltage got down to a certain level (say 12.X volts) or after a certain amount of time (say X weeks)? If I would be better off, what would be the best voltage or interval?
    I must say, the forum has changed a lot since back when I used to be a frequenter here although I see a few familiar names. Going to have to nose around and catch up.
  • littleharbor2
    • Jan 2016
    • 224
    Being that AGM batteries have much better shelf life than FLA batteries I would avoid any Cheapo maintainer and give a full charge every 4 - 6 months..
      • 15152
      Just remember that each time those AGM's discharge you need to drop a cycle from it's life. While they may last longer then FLA type as litteharbor2 states they will still lose life just sitting there.
      I would not trust those AGM's to provide their nameplate amp hours after a couple of years so plan accordingly.
