AGM battery high self discharge?
  • micky 32
    • Jan 2023
    • 6
    Hi all. I have one of those start/stop energy recuperation cars coming on 6 years. I think the battery is usually kept at a SOC of around 80% charged for most part.
    Over the last few years it's cranking isn't as strong as it used to be compared to when new, but expected as the battery ages. It still starts at -7 degrees C.
    I left the car at the airport for a week. I have one of those BM2 Battery monitors on the car. It was a 2 hour drive and the alternator was charging the battery full whack for the 2 hours at approx 14.4v. Here are the results after sitting for 7 days:
    Day 0 : 12.71V
    Day 1 : 12.59V
    Day 2 :12.50V
    Day 3 :12.49V
    Day 4 : 12.45V
    Day 5 : 12.44V
    Day 6 : 12.42V
    The car started ok but was sluggish. Is this a high discharge rate or just due to normal parasitic drain from the car? Is the battery toast?
  • organic farmer
    • Dec 2013
    • 686
    Originally posted by micky 32
    ... Is the battery toast?
    I dont think it is toast yet.
    It still has enough power available to start the ICE, so your good.
    But it is aging.
    When parked at home, do you keep it plugged in?
    To my understanding what kills batteries is cycling.
      • 5244
      One thing often ignored in a starter, is the brushes worn to
      end of life. A new set are regular maintenance here. But,
      perhaps that starting arrangement does not use a brush motor.
      Bruce Roe
      • micky 32
        • Jan 2023
        • 6
        I put a conductance tester on it today. The battery is rated at 680 A (EN/CCA). The results were 350 A (EN/CCA) 26% SOH with the message “ REPLACE”. I’m sure 350 A is still enough to start a 2.0L diesel engine for another while i’m sure.
