My two 48 volt paralleled FLAs total around 1000 Amps capacity total on my solar trailer. Using the midnight solar controller that came with the trailer I can select manual Equalization. There is a 7 KW diesel on the trailer. From "Float charge" on the charge controller display it took about 1 hour to equalize (start to complete). I think It read 1.3KW of charge current during equalization (but not sure what the value referred to) Having no reference, is this "good" for the batteries or "bad"? I have not messed with the settings it came with. There is a sunny island inverter that supposedly counts cycles and auto engages an equalization but to date I have not seen it do this and have not tested that function, I assume that is why autoequalize is disabled on the charge controller as the sunny island starts the diesel as needed. The batteries get light use and have desulphators so I am trying to do a manual equalize every 3 months, is this too often or not enough? The batteries are outdoors and it gets cold in northern NH. My assumption is keep them charged preferably on float all winter?
Once I wade through the settings and add another expensive 50 AMP power cord I can skip the diesel and equalize from the grid. My guess is the Midnight Solar controller will draw the same amperage for the equalization be it from the 7 KW diesel or from the grid?.
I plan to check SGs tomorrow. They were good the first time I checked 3 months ago.
