I'm looking into buying a forklift battery for an off grid system.
I found a new GB industrial 985 AH@20hr 24-125-11
There is also a GB 24-85-13 803 AH@20hr and it is less amp hours, but more expensive.
Will the second battery last longer than the first, and what's so special about it that makes it more expensive?
Is GB a decent brand, or can anyone make any recommendations for a new forklift battery?
If the ah is 985, what is the max amount of panels can I run to this battery? A kwh calculator shows 47.2 Kwh
If I had 30 panels at 280 watts each, that's 8400 watts. So it would need 5.62 hours peak sunlight to charge the forklift battery if it is discharged to 0%. Not saying you should go that low, I'm just trying to grasp the concept.
Is this too much panel or not enough? Thanks
