I am KF5LJW and you know what that means. OK you fit the AGM profile. An AGM battery biggest advantage is the very low internal resistance, lower than most lithium types for a given capacity. What that means is they can withstand very high charge and discharge rates expressed as C-RATE. A typical FLA battery can only deliver about a C/8 maximum discharge rate without suffering significant voltage loss. A C/8 Discharge rate would be 10-Amps on a 80 AH battery. A 80 AH AGM on the other hand can easily supply 20 to 40 amps. Some AGM batteries made for Telecom. Space Craft and UPS can deliver as much as a 4C rate or 15 minute discharge rate. On a 80 AH battery is 320 amps. But it comes with a cost.
As for battery voltage and size depends on the application. More importantly how much power are we talking about. 12-Volt systems are small toy sized systems. They are not capable of doing a lot of work. Example if your panel wattage or inverter is larger than 500 watts, is time to move up to 24, 49, or 96 volt systems. Bottom line is this: Never ever parallel parallel batteries. If you need 400 AH, then buy 400 AH batteries. You will not find 400 AH 12 volt batteries. You would have to use 6, 4, or 2 volt batteries in series to make 12 volts.
Whatever you do, do not listen to ham radio operators to tell you how to use solar, battery, or anything about Grounding or Power. 90% of them have no clue.
FWIW, to have backup power, solar is the last thing you want. No commercial radio operator or any professional uses solar for back up power. All of them use a Battery Plant and Rectifiers to run all the equipment. Nor would you want to use solar on radio equipment. You will soon discover why with all that noise you will be generating will wipe out your RX. Only good reception will be after sunset. If you want battery back up for your radio toys, use your Astron PS as a battery charger, and float your batteries. Your batteries will last 4 times longer and no NOISE.
