Greetings,
There seems to be two schools of thought about lead acid batteries for backup (float service).
One recommends flooded batteries. Proponents main argument is that if you made a mistake you can equalize them. This argument is unquestionable, is true. That is one of the advantages of flooded batteries. The second one is cost. But it seems that the recommendation is not a generic one. Most authors (tech documents) and proponents (Sunking) usually recommends them for float service only if they are lead-calcium. Those type (flooded) are not commonly available for off grid use. They are mainly used by the telecom industry. What most of us can get are lead-antimony (RE: L16 and Golf cart, etc.) It seems that most manufacturers do not recommend them (although one manufacturer says that you can use them but at least deep discharge them once a month {source: web seminar}). Mainly because of stratification and lost of capacity in float service (although, according to one manufacturer you can recover the capacity if you cycle them).
The other school recommends AGMs. Mainly because they are maintenance free (but you should check and retorque connections 2 times a year). The second reason is that, because the electrolyte is captive, the do not suffer from stratification. The third one is that most of them are lead-calcium (like to float). The disadvantage is that lead-calcium has less cycle life than lead-antimony. Another point in favor is that in most backup applications the battery is going to die because of age, not because of end of cycle life.
Personally, I’m more into AGMs, for backup (float service) because, as several pro installers have told me, people (grid tied) tend to forget they have batteries that they have to maintain. This happened to me with two golf cart batteries. Left them on the charger and 4 months later remembered them. Fortunately, the plates were still (barely) covered.
So, my question is: Do you think that, even with its disadvantages (stratification & lost of capacity) that flooded lead-antimony batteries are worth it in backup applications? If you have flooded lead-antimony in float (backup) service, please let us know what your experience with them has been. Thank you.
