Does anyone know what is the AH or kWh for the Sams Club GC2 battery?
To prolong the life of battery, from CC, I set the cutoff voltage at 24V which mean when battery reach the level of 24V then the inverter will shutdown.
I'm in Southern California, the panels faced South at the angle of around 35-40 degrees
During this time, sun rise at around 6:00AM and set at 8:00PM. I have about 11 hours of sun
As you can see from the screenshot below that I just took from my phone at 6:39PM, the panels still produced 52W with today total of 4150Wh as of 6:39PM. This reading is from CC which has the same reading as my Current Clamp meter and Fluke 87 Volt Meter.
I have Clamp Meter and volt meter connected to solar input of CC. The reading on those 2 external devices are the same as CC display.
I also have clamp meter and volt meter connected to the inverter input. The Kill-a-Watt meter connected to the output of inverter. The reading on those 2 external devices is about 10W higher than the reading from Kill-a-Watt. (I assumed that 10W loss is from the inverter)
The graph below show today reading for the last 6 hours.
