Two of my golf cart batteries died and being inquisitive I did a lot of reading on how lead acid batteries actually worked. My inquisitive nature then went into overdrive and I took an angle grinder to one of them to have a look see. Not a pretty sight because the failure was that the lead grid inside the positive plate had corroded away to nothing and there was a sludge of oxide and lead fragments at the bottom of the case shorting everything out.
Now the question. Instead of a lead grid for the positive can something like Alloy 20 or any other metal designed to resist H2SO4 be used instead?
I was considering recovering the oxides, washing and neutralizing them, then using hydrogen peroxide per the patent to make a paste and then paste into a grid made of corrosion resistant alloy or maybe even a conductive carbon.
Is this realistic or am I missing something?
