I know I'm going to get roasted for this but...
Here is the scenario:
I have 6 120 AH 12V AGM Deep Cycle batteries connected in parallel in the off-grid cabin I am finishing. I have 7 Renogy 100 Watt mono panels, 60 amp MPPT charge controller, and a 3000 watt pure sine wave 12v inverter. Up until now I had them hooked up the "lazy mans" way and research has shown me this was/is a bad idea. My next trip to the mountains I will be re-wiring them for a more balanced setup. I bought an IOTA 45 amp charger and will also be hooking that up so I can charge the bank via my generator when sun is scarce.
I have found a lot of wiring diagrams to connect 4 batteries in parallel so they are "perfectly balanced" but I have not found any diagrams for 6 batteries. Will it be as easy as hooking all + to a copper buss-bar with equal length cables and same with the - side? I know everybody hates parallel battery banks but for the next several months I'm stuck with this arrangement.
I realize I should have did more research before doing this and have realized the errors I've made and plan on correcting them when finances allow. I will switch to a "name brand" 24V inverter/charger and reconfigure the batteries to series/parallel to run the inverter with. But, for now, I am going to have to get by with the 12v inverter. It's a Chinese inverter (Reliable Electric) but so far has worked nicely and hopefully will continue to do so until I can get a Magnum Energy or AIMS Power inverter.
Thanks in advance,
Justin B.
Thanks in advance,
Justin B.
