Yes, that seems pretty close to what it has been running.
can be any time, actually, usually around noon
100w HF panel. Sadly, it's turned out that the cardboard the panel comes in, is more valuable than the panel. But while it's working, great
Lol, I know HF has a bad rep on these forums. I bought them because I needed an energy source on short notice last August and renting a generator was twice what the panels cost. They were perfect for my needs and as far as I'm concerned, they've already paid for themselves. Anything else I get from them at this point is a bonus.
Got it
Actually our power here is super reliable and I may never need to use this option, but I want it just in case of emergency. If my basement flooded, it would be very expensive for me.
Thanks for the information!
When do you ride the bikes Noon ? Morning ? Evening ? It matters because you will either be charging directly from the sun, or storing power in an intermediate battery.
The most practical battery is a cheap battery, generally a 80ah 12v battery. 100w charging it, is barely sufficient, but it's all in the timing.
, using the inverter to charge the bikes in the morning so solar can recharge the battery in the day, is preferable to using the inverter to charge at night, and letting the battery sit drained all night.
The longer and deeper a battery is discharged, the shorter it's life, you want to maximize solar utilization.
Sump pump. Would a 12V marine bilge pump, if it meets the flow and lift requirements, be a option to avoid an inverter ? How often does Grid power pump fail and what expense are you willing to go to for a 80% solution or do you need a 99.5% solution ? If grid fails, that means storm which means no solar for recharge .
