So I joined in on a discussion about charging and Battery Life here the other day, and was suggested I start a new thread. After thinking more for a while, re-reading the responses there and processing it all, I decided to start this thread to clarify and correct my thinking.
In the linked thread above, Mike Wrote:
If I am understanding this comment correctly, max SG does not change from the original electrolyte level.
So if my Hydro reads a number higher than what the manufacture says is the 100% charge number (for Trojan that number is = 1.277), and no other issues of contamination have occurred in the battery ... does that mean I charge to the highest number that my hydro reaches (the point where the number stops rising) and assume my hydro is off and incorrect?
Or does the manufacture built in an amount of electrolyte that would allow a hydrometer to read higher than the manufacture 100% charge number of 1.277?
Another way to look at it (or say it) .... if the manufacture says 100% is 1.277, but I can charge the batteries to 1.298 according to my Hydro, do I assume my hydro is off ... and charge to the highest number I can reach (my 1.298) until the batteries stop receiving charge, or do I go to 1.277 because the manufacture has built into the SG more acid than they want the user to rise to? (that last part is probably stated incorrectly, but I hope you understand what I am trying to say)
I am using and comparing both a glass hydro (the one often recommended here) and the MidNite Solar Hydro-Volt. Both have temp comp. I am getting very similar readings from both.
Also ... I realize increasing the voltage increases the amps during charging, but does increased voltage hurt the batteries (unless there is heat build up and the batteries get too hot) . My problem is my charger keeps turning off before the max SG is full reached if I use the Trojan 29.6v number unless I increase the volts. Both the solar and AC charger do this. And I have adjusted the voltage of both to reach 1.277 in the highest cells in the battery bank. I have the voltages set about a volt or more higher than Trojan's charge voltages - at about 30.8-31v for absorb. BUT if I have to use my Hydro's highest number reached because that is the real 100% charge number for me, I will have to increase those voltages even more. Is that a bad thing?
(Note: I have never over heated the batteries. Even at my higher voltage levels ... they just don't heat up. And they hardly use any water in 3 months since putting them into service new in Oct 2017)
