I have an Outback Radian GS8048A inverter/charger connected to eight Rolls-Surrette S6-460 AGM batteries in series. It is a hybrid setup that operates in grid-tied mode but can continue powering my critical loads panel for a while if the grid goes down. So far it's working great, maintaining my batteries at float voltage with less than an amp of average charge current while inverting the rest of any DC current provided by my two charge controllers. Any solar power not consumed by the loads on the critical loads panel gets backfed to the main panel to run my other loads (water heater, stove, washer and dryer) and, if there is still an excess, back to the grid where my shiny new net meter will count down instead of up.
While the grid is available--the vast majority of the time--the batteries stay at float voltage with only minor deviations. My question is whether I should be letting them discharge occasionally and then recharging them with a bulk and absorb cycle. I can initiate this just by switching off the 50A breaker for the Radian at the main panel and then turning it back on after my FlexNet battery monitor reports SOC getting down to 50%. (It's a Coulomb counter that should follow a single discharge down from 100%/float SOC accurately enough.) If the sun is shining during the day, it might take me a few days to get down that far. For recharging, the Radian's charger will kick in once AC voltage is detected from the grid and selling AC won't commence until the charger has gone through its full bulk-absorption cycle, possibly with help from the solar charge controllers.
I've read comments from various anonymous Internet experts online about "exercising" deep-cycle batteries but am a bit skeptical about that. Seems to me that keeping a lead-acid battery at its float voltage should present the least wear and tear of any other possible usage. Any thoughts from members of this august group? Sunking ?
