Here is the deal.
I have two separate solar systems in two houses close to each other.
In one house I have a set of 8 Trojan L16H-AC 435ah batts in series for 48V, this set is 6 months old.
In the second system I have a set of 8 Trojan L16 RE-B 370ah in series for 48V, this set in one month old.
Both battery banks fully charged to SG of 1,280 temp compensated.
After a 15 hour nightly discharge totaling 90AH on each bank on the same day under indentical conditions (i.e hourly draws match etc) , the SG readings on both banks are exactly the same 1,240 temp compansated.
Does the 370ah actually then have a capacity closer to 435ah? As SG reading indicates a 20% discharge on both sets despite one has less capacity. Therefore SG on 370ah RE-B should be a bit less, NO?
SunKing??????
SunKing??????
