After inetdog pointed out on a different tread(thank you) that a shunt to monitor a battery bank is not absolute reliable as you will need to measure individual batteries as well, I did and to my surprise I found 12.65;12.60;12.72;12.65. This is string of 4 batteries of 12v into a 48v system. That's a difference of 0.12v between the 2 of them under a constant 250w load as the bank is feeding the inverter where I got a fridge/freezer ,tv and lighting . This translates to about 0.02 per cell , is it acceptable ?
I came across on the net a while ago about a device that you fit in the string between the batteries to direct current accordingly so it balances out but can't find it anymore.
The battery links are 25mm copper cable with crimped and soldered copper end lugs.
Any input is much appreciated . Thank you
