does this work?
epsom salts for rejuvinating dead FLA batteries
= Dead Battery. Anything other than distilled water = dead battery. Every bit of Free Sun used on a battery will be a Boat Anchor soon.
But hey kick a dead horse, he will not care what you do to him.MSEE, PE -
SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
I see the Ethylenediaminetetraacetic acid aka EDTA touted around the Internet as a battery rejuvenation. It all seems like a lot of work for a unknown outcome and it's dangerous fooling with electrolyte without the proper equipment.
http://leadacidbatterydesulfation.yu.../EDTA-wpulsingComment
You canno thurt a dead horse, but you are still out $10K, plus disposal cost.MSEE, PEComment
Still find it hard to believe you have not had the mains power reconnected. I would have put all my energy into getting that sorted rather than continuing with stand aloneComment
Actually, we have a thread on this topic, that does explain it more clearly: http://www.chemicalforums.com/index.php?topic=67944.0 Briefly, a completely discharged lead-acid storage battery has the sulfate making up the plates. http://en.wikipedia.org/wiki/Lead_ac...tery#Discharge with almost no acid in the solution. The magnesium sulfate is a good, cheap, reasonably pure (USP grade, which does not mean a pure reagent, but is close enough for this application) conductive electrolyte. Now the discharged battery will conduct again, and a trickle charge will recharge the battery, converting the plates and creating sulfuric acid in the electrolyte. http://en.wikipedia.org/wiki/Lead_acid_battery#Charging And yes, you should now dump out the mixed magnesium sulfate-sulfuric acid electrolyte and replace it with the proper sulfuric acid electrolyte. You don't want the battery to be more conductive then normal, that will enhance auto-electrolysis, a side effect of the battery -- the battery will lose water, and generate hydrogen and oxygen. And you don't want hydrogen close to a battery, an alternator, an engine full of fuel, your groceries, ... you, etc.
Briefly, many things can go wrong with the lead acid storage batter. Certainly, excessive charging and discharging can buildup sulfate on the plates. They're also prone to flaking off of material, due to shock and vibration, freezing of the discharged battery warping the plates, and shorting out of individual cells by buildup. This magnesium sulfate trick seems like a good way to bring the battery back, but the conductive salts should be flushed out, and the electrolyte replaced, before we reuse the battery -- that's the bottom line.Comment
I cannot predict the effect on the battery, but it will depend a lot on the original thickness of the plates. An RE battery would be more likely to survive the treatment, but with less durable plates, than a thin plate cranking battery.
Also, once you add the fresh electrolyte at the proper SG, you should not need to do much if any charging to the battery, since it will be in a modification of its original 100% SOC state. You may need to run through several discharge/charge cycles to reform the fresh plate.
I cannot recommend this, since I have not heard from anyone that I trust to evaluate all of the factors involved.
This might be a viable SHTF scenario option.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
This will only work at the expense of decreasing the thickness of the lead plate and increasing the thickness of the lead oxide plate.
This might be a viable SHTF scenario option.Comment
