Hi, I have bought 21 6x6" Kyocera cells for my kids science project. Each cell is rated at approx 4.5w, 0.6v, 7amp. Exact specs are below.
If all the cells were connected in Series, I would end up with an approx ~90w panel, ~10-12v, ~7amp panel. I hope I am correct here.
Now my kids Kid-Trax ride is powered by a 12v 12ah battery which gets charged by a Charging adapter plugged into a 110v outlet. The adapter says 12v and 12w implies it is supplying current at 1ah.
Now, will I fry my battery if I supplied 6-7amp DC current straight to the battery or to a charge controller. The battery does not have any specification on max current !? If true, what would you suggest to step down the current w/o affecting the charging voltage.
BTW, I am already a proud Homeowner of 6kw Suniva/Enphase Solar system. So kids are excited about doing this Solar project. Did not know of any other place to ask this question.
So thanks again for your help.
Cell Specifications:
Efficiency Eff (%) 15.2-15.75
Power Ppm (W) 4.0 - 4.5 watts
Max. Power Current Ipm (A) 7.89 - 8.25
Short Circuit Current Isc (A) 7.73 - 8.85
Max Power Voltage Vpm (V) 0.521 - 0.561
Open Circuit Voltage Voc (V) 0.623 - 0.625
