I was recently given eight Rolls 4000 series 375 aH 6v batteries manufactured in 2005. I was told that they were used for a few years then put on a shelf. I understand that they are most likely suitable only for recycling, but since they had a 10 year warranty and a 20 year estimated service life, It is worth trying something.
I have access to a charger which will do 6 or 12V at 2,20, or 60 amps. It also has an auto mode and a starter mode which I think is 125 amps. I also have some small 12V 5A chargers.
Without any charging, the batteries range from 2.5 to 3.5 V. Even if I could get them to half their original capacity I could use them for a project I have.
I charged one at 60 amps for several hours yesterday. It got a little warm (The cables were hot) and was bubbling slightly. This morning the voltage was only 5.8. I'm going to charge it for a few more hours today at 60 amps. I could also charge them with the charger set to 12V. I tried this for a minute at 20A and the voltage came up to 7.1 while charging. I'm not sure how long or at what current I should do this.
There's a local battery shop which will drain and re-fill batteries. One thought is to drain, treat with EDTA, , flush, then re-fill with new acid. I wouldn't be doing anything with acid myself.
The project I need these for will have a constant current draw of only 3 amps @ 12V and a single 250 watt panel. The batteries are just for nights and cloudy periods.
