Just a quick warning after a friend boiled his brand new agm for 3 hours with one of these on the agm mode ... (wish he would have called me because I went through it myself)
Went through three chargers around the neighborhood that like to go into high voltage EQ voltage on well-maintained batteries on their own without user permission: SC-1000A, SSC-1500A, and a SC-7500A.
Essentially, they eventually like to go .7V too high on each setting, usually pushing them well over 15 volts and way too soon, which in the case of agm's and especially gels is usually not recommended by the manufacturer. However there is a workaround for this aggressive behavior. The units that had a voltage display option were at times not accurate - a Fluke 87V voltmeter across the terminals told all.
1) Don't ever use gel batteries with these.
2) Use the mildest setting "gel" for agm and flooded. Apologize to friend for confusing him about using gel mode when his battery is really agm.
3) In reality, choose the best measured voltage, and not the labeling for your application.
In the gel-mode with my agm's that like to see 14.7v absorb guess what? Yep, 14.7v absorb was reached which tapered down to 14.4 volts at the end of absorb before going into 13.6v float. And that's gel mode! My Optimas and Odyssey's like it. It might be a tad too high for lead-calcium agm's like East-Penn/Deka, but at least it is no longer pumping out 15+ volts with the resultant snap-crackle-pop heard inside the battery for 3 hours.
If you mistakenly start out in a non-gel mode, disconnect cabling and start again - seems that merely changing the battery mode while powered up doesn't convince them not to do the high-voltage treatment.
This gel-only-mode workaround seemed to work best on the chargers that had non-sliding amp selections - that is, the 7500A has a sliding 10<>20 amp mode which oscillates back and forth when charging. Unfortunately, even when set to gel mode, when it oscillates to the 20 amp mode for a few minutes, the high-voltage treatment is back, even though you have overriden it with the gel mode. The smaller 1000A and 1500A worked like a charm.
Obviously a higher-quality non-automobile charger is a better idea - along with solar and a decent controller. But if this is all you have, please try one run in gel mode even though you aren't using gel batteries. It could save you some $$ and actually have a useful charger in the end.
