temperature influence on state of charge
  • Lee72
    • Feb 2012
    • 28
    Hello members,
    I am not clear about temperature influence on state of charge for SLA batteries. I have found several tables in the web that state the opposite. Here are 2 question:
    1. I have a battery with 100% SOC at 80F, voltmeter = 12.7V. If i now put the battery in a warmer place (100F) will it read more, lets say 12.75V ?
    2. Chargers compensate for temp, my Mornigstar does -28mv/C meaning lower voltage with higher temperature. why is lowering the voltage?
    Thanks in advance
    Markus
    Mark temperature compensation is inverse coeeficient meaning as temps go up, voltage comes down. SOC voltages on a working system are pretty much useless.
    • PNjunction
      • Jul 2012
      • 2179
      With my various sla's, I've never really noticed them raising in voltage when the ambient temperature was raised. They will however have a faster rate of self-discharge as the temps rise.
      Normally the manufacturers charts center around 68-78F, and the compensation up or down begins from there when charging.
      Good quality products do temperature-compensation, usually ambient at least, and the best incorporate a temperature probe to get as accurate as possible with actual battery temps - which also help guard against thermal runaway. Note that batteries take a bit of time to release or absorb heat - a quick change in ambient temperature may not be noticed by the battery right away, so the probes are the best bet - but ambient is better than nothing.
