Just as a matter of learning more about how batteries and charging works, I am curious about the current which flows between the batteries while they are being charged. I have 5 12V batteries connected in parallel. Let's say they are numbered 1,2,3,4,5 and the positive from the charger is connected to battery 1, the negative from the solar panels is connected to battery 5. A typical observation that I have made is this: the charger at the time is delivering 8 amps, on the positive side the amperage between 1 and 2 is 5.9, between 2 and 3 is 4.1, between 3 and 4 is 3.0, between 4 and 5 is 1.6. On the negative side, between 5 and 4 is -8, between 4 and 3 is -5, between 3 and 2 is -3.6, between 2 and 1 is -1.9.
So, given that the amperage between the batteries during charging reduces as the battery gets farther away from the source, are all the batteries actually receiving the same amount of charge? What is actually going on?
