I am considering the purchase of a pair of Interstate Marine/RV Deep Cycle (Group size 27DC) batteries to run a baby off grid 100 watt ham radio station. (100 watts only on transmit; 12 volt radio with one amp on receive and 18 amps or so on transmit. I would only transmit at part time even on a busy contest and usually the radio would never be used more that 10-12 hours even on a contest day)
I found these batteries at my local Costco. My research indicates that these are built by Johnson Controls which I believe makes a good battery. They have a 750MCA / 160 RC rating but I don see a KWH rating anywhere and I have checked their web site too. So I am wondering if anyone who reads this are familiar with these. Are they reliable? Is it OK to use these indoors in a well ventilated room? Should I bag that idea for a single AGM battery? I like the idea of having the battery (batteries) indoors as I live near Phoenix. I think I would remember be more diligent about checking fluid levels if they are indoors.
I plan on charging these batteries with 4 New Old Stock Photowatt panels PWX500 (17V@3 amps typical) using a Trace/Xantrex C40 charge controller. All of these components are in fine working order. I think this should run the radio and a few minor accessories and low voltage lighting just fine, even if I have a few cloudy days. (Any advice on lighting? 12v LCD/LED???? or whatever.)
Thanks for reading this and thanks in advance for your advice!
Steve WU9B
Steve WU9B
