I have two identical telemetry systems on top of water tanks. The telemetry consumes about 180 watts/day. It's powered by solar/battery. I want the system to have enough power to run for 7 days without sunlight. For that I'm using two 6V 225AH deep cycle SLA AGM batteries in series from vmaxtanks.com. There is a single 330 watt solar panel and power is mediated by a Victron 100/20 charge controller. The system was installed in Nov 2019. These batteries are in battery boxes but outside where temps can get into the single digits for short periods and below freezing temps in the winter are common.
Besides other things, the telemetry monitors battery voltage and sends an email if it goes below 12.0 volts. I've started to get these emails from both systems. I thought the batteries would last for at least 5 years. Does this make sense that they would only last for 2 years? What would reduce their life? With a maximum discharge to 50% I have 1320 watts available and the telemetry uses about 90 watts overnight, or about 7%. So the battery is being maintained near 100% charge. The charge controller will stay in bulk charge for an average of 336 minutes which seems rather long for batteries that are discharged only 7%. When it switches to absorption it will spend an average if 142 minutes. And after that it will spend 315 in float with the bulk of that time during the summer.
The odd thing is that the change controller tells me the minimum battery voltage was 12.27 volts. Next time I'm over there I will check the voltage with my DMM and see if the charge controller and/or telemetry voltage is off.
The question is this. If I need to replace the batteries is there a better option? Lithium? LIPo? Cheapest ~220 AH batteries I can find? And do I perhaps have the wrong settings on the charge controller? I pretty much took the defaults for the SLA AGM batteries.
Thanks,
Thanks,
