I made a bank to test a 24v inverter yesterday, battery bank consist of 4 100ah batteries. I used random cables I had like 1/0 welding cable for inverter leads and used dual 8 awg cables for the battery jumpers. My voltages are really low on the batteries that have the inverter leads hooked up. I was running a constant 600 watt load so thought the cables would be fine for testing at this load. The readings are right before I turned off inverter and I had not noticed since I was going by the 22v reading instead of individual batteries. If the issue is caused by the dual 8awg wire would 2awg be sufficient for the battery jumpers or will I need 1/0 all the way.
