Equalizing the bank
  • PhotonJack
    • Nov 2019
    • 7
    Equalizing the bank
    Greetings fellow sun followers,
    With the sun at such a low angle and lots of overcast days, my bank is getting a useful charge, but not enough to kick the controller into equalize mode and I don't want to go too long without doing so. Haven't seen bubbles in at least a month. Is there a recommended 'forced' equalizer device I can add to the system? Other options?
    Obviously a noob. Thanks,
    Jack
    Yes, watch the weather for a forecast for a fairly sunny day. That morning about 7am, start the generator, and Bulk charge the bank for the couple hours needed to get thru Bulk and at least part way through Absorb. Then you can initiate the EQ cycle. The further along in ABSORB you can get before judging you won't have enough sun left to get some EQ done, the better, you can't EQ bateries till they are charged, otherwise you are merely charging them.
    This post here, talks a bit further about the process.
    Hello fellows. I'm new to this forum and a newbie to solar energy. i'm located in Greece. Most of the time sunny and it's a pity not to harvest the sun. My system consists of Renogy Rover 40amps mppt charge controller. Canadian solar Solar panel 320w 24v 9.3amps 2x varta dual purpose proffetional lsf 105 batteries 12v 105ah.
    • PhotonJack
      • Nov 2019
      • 7
      Brilliant! Will do, thank you very much!
