Battery string isolation
  • -robw-
    • Sep 2019
    • 69
    What I'm wanting to do is to isolate each of of my 2 battery strings on a Perko switch to ease monthly~ equalization of each string. Is there any downside to what my drawing proposes?
    You better find out if that switch is Make-Before-Break or Break-Before-Make. Break-before-make stands a good chance of glitching your inverter & charge controller.
    • -robw-
      • Sep 2019
      • 69
      I would shut both down before switching, but "Always STOP engines before switching to "OFF" position. Make-Before-Break feature allows switching between 1-all-2 positions with running engines"
        Remember that some CCs will not reboot after battery loss unless the PV input is turned off first so that the battery is the first voltage the CC sees.
        • -robw-
          • Sep 2019
          • 69
          Yesterday I witnessed where you are coming from. I mistakenly switched the Perko switch to off while testing system, and fried it once I switched it on to a battery source while CC's were supplying current. *SPARK*, that sucked. Luckily I had another on hand and the 1st thing I did after reconnecting everything was write "TURN OFF POWERS 1ST" up top.
          Hopefully I'll read that in future!
          Other notes:
          Bad start with Magnum MS4448PAE. Manual indicates it needs just 5w to kick in but a more than 5w AC fan would not. I think instead, Magnum means 5w continuous but more to actually kick in. Since energy output on this system will often drop to zero I'm now in need of a 48v battery box fan.
          Should have stuck with 2 Classics instead. I'm now aware that there's no way to set or communicate with FM80's until a $300 mate is added. Seems Outback went out of their way to force this add-on charge, and that's bad business if not made clear upfront.
          Sunking's https://www.solarpaneltalk.com/forum...your-batteries got a thumbs up from a Crown engineer, although he suggested doing it in reverse, ie, follow battery specs first and then adjust bulk, absorb and float UP until refractometer/hydrometer is happy. That way batteries won't get stressed. Fantastic sticky, nonetheless.
