Mixing battery chemistry
  • NeilTheCop
    • 53
    My small solar system is/was comprised of 4 * 6 volt golf cart batteries wired in series/parallel to give me about 200 amp hours at 12 volts. Two of the batteries have died simply due to old age and now I'm using the remaining 2 fairly new batteries in series to give me the 12 volts. Rather than just replacing the two failed batteries with more SLA ones I was going to upgrade to Lithium Iron Phosphate prismatic cells, and also upgrade my modified sine wave inverter to a pure sine wave 24 volt input.
    My question is can I mix and match the two chemistries and connect the SLA and Lithium batteries in series to give me the 24 volts until the remaining SLA's die and get replaced with more Lithium cells. Or will magic smoke and major damage ensue?
    You are not absolutely guaranteed loss of magic smoke, but it would be very hard to avoid it. Batteries in series must carry the same current at all times unless you use two chargers, one for each set of batteries. The SLA and any Lithium chemistry will have far different reactions to overcharge. The SLA requires it (although not at high currents) while the Lithium simply cannot tolerate it without damage.
    It is a tempting thought, but I personally would not be comfortable with it, even with extensive custom BMS and close monitoring.
      In short, I'd recommend AGAINST it. It would be very difficult to engineer it safely & well. The cost of catastrophic failure with Li cells is high.
        • 2331
        You could probably get away with it for a little while if you use a good BMS. If not, you'll get one or two charge cycles, tops, before you destroy one or the other.
        • NeilTheCop
          • 53
          Thank you all. I decided to run two separate systems, one 12 volt SLA for light loads and a complete new 24 volt system with Lithium for the heavier loads. When the SLA's die everything gets switched to 24 volt Lithium. Unless of course one of the "Groundbreaking, new, wonderful, game changing" battery technologies ever actually comes to market
            That sounds like a good plan. What type of Lithium batteries are you using?
              "... Lithium Iron Phosphate prismatic cells,...."
                I meant to ask what brand?
                • NeilTheCop
                  • 53
                  Not sure yet, but if the tariffs with China go into effect the whole idea may be put on hold for a while as I'm sure the prices will spike
