You cannot fix it, law of physics will not allow you to fix it. You have not offended anyone but yourself. You will soon figure it out when your wallet beats the crap out of you, gets your attention, and teaches you the hard way by loosing a lot of money.
What you do not know is batteries cost money and have a negative EROI. Basically that means they will never give you more energy than was put into them to make the. Sure the POCO is ripping you off at 30-cents per Kwh. Geez and rice where I live is less than 10-cents, si I understand why you think you are being robbed, you are. But what you do not understand if you buy quality batteries that give you the best rate of return for your investment the energy in battery cost alone is going to be $1 per Kwh. I do not know what math democrats are taught, but us independents and libertarians know 30-cents per Kwh is less than $1 per Kwh. However you can only get it down to $1 per Kwh by using optimum design and quality batteries which you are not doing, so in the end, you will be replacing your batteries more frequently every year or two when your wallet finally throws a fit and teaches you a lesson. There will be no one to blame but yourself for not understanding what you are doing.
Do you want to also talk about the cost of all the other equipment to make the batteries work? It really get ugly. Not only wil it cost you more, you just because a very heavy dirty polluter. Why? That negative EROI thing again. At 50% efficient overall you used twice as much power to make the batteries that is never recovered. You just robbed your children of resources and added a lot more pollution to the air.
There is no way to win with off-grid solar. The law of physics will not allow it. To bad schools today do not teach math and science anymore.
