Hi folks - new to this site/forums - I did some searches, couldn't find a topic like this - but apologies in advance if this is a duplicate post (please send links to a relevant thread, thanks).
I'm experienced with 12v solar setups using both lead-acid and Lifepo4 batteries. I'm thinking about embarking on a rather ambitious diy campervan build, and I want to build a bank of LIfepo4 batteries that I can plug-and-play. I'm calling this 'asynch' as I'm a developer, probably not the right term -
But what I want to do is this - Let's say I have a bank of 6 x 60ah Lifepo4 batteries. I want to unplug 2 of them at night for astronomy use, then plug them back in the morning (won't be full discharged). I want the other 4 batteries to stay working for everything the campervan will need.
So - I'm thinking a very simple toggle switch of somekind separating the 2 asynch/hotswap batteries will be all I need. Before disconnecting, I just throw the toggle to keep the main 4 still in chain.
Any ideas about this? Am I explaining this enough for what I want to accomplish?
EDIT: Oh - forgot to mention - I intend to have a solar controller (panel above), inverter and shore charger hooked into this main pool. So when all batteries connected, 6x60ah, at night for astronomy take out two (flip toggle?) and bank has only 4.
I think my main concern is wiring (would a simple toggle work?) and I don't want to damage the batteries. Given they will be at different charge levels at different times, I don't believe this is a concern - my understanding of chained batteries is they will just flow to even across the whole pool as long as the batteries are identical.
Thank you.
Thank you.
