Thought it was a about time I had some power backup for my reef tank, along with my TV, a few lights, media center etc.
I grabbed these off ebay, 100 AH AGM FIAMM for standby use, which is perfect for my setup rather than solar. So far they have all passed discharge and charge tests under a 20amp load each. Im running a 380w pure sine wave inverter and a 20a bench power supply which charges the batts after a powerout and then simply supplies any loads. In a setup like this with load a normal battery charger will stay in boost and boil the batts, so a power supply is the way to go, some battery chargers have supply mode for this application. i have tracked down a proper charger for standby setups like this, but tis a cool 500. Bit heavy on the wallet at this stage, i mainly want it for temp compensation.
