I've been lurking and learning. Thank you for the information
We (family of 4) started with top end 2-6V for 240Ah AGM in our 5th wheel trailer. These gave us 80-90Ah usable from 12.7V down to 12.0V(under load). Our next move was to pull the AGM out and go with 4x6V (440Ah) generic FLA. The FLA keeps us going for 2-3 days in the summer but on winter ski trips with the heater running, being inside more and colder batteries the bank needs to be charged after 24hours or the voltage drops below 12.0V the next morning.
The batteries may be charged to 90% SOC but never to 100%SOC due to amount of generator run time that is needed. The 1.3Kw of solar being added will be of limited use in the winter.
A 24V or 48V bank was a consideration but the trailer has a leveling system with four 12VDC motors that draw 70amps each, 140amps when the motors run in tandem.
Charging was done with a 50amp (with temp sensor) charger. A Victron 12/3000/120 (oversize for our needs) inverter charger, GX control, 150/100 controller is being added.
The battery bank was located in a side compartment at the front of the trailer with no heat. At 5 degrees F the compartment will be 20F
To keep the batteries warm I utilized some dead space between the frame rail to build a compartment that is 6" W x 22" L x 15"H. It has 3" of XPS foam around it. A warm air duct that heats the tanks also heats the compartment but it may not be enough to keep lithium above 35F when it is 10F or colder outside.
Depending on battery size the new compartment can hold between 800Ah(6V Golf Cart) and 2000Ah(Lithium cells)
Considerations:
- FLA - Least expensive. Longest life. More weight. Requires a watering system. Sealed & vented battery box has to be built. Charges below 32F
- AGM - 50% more $ than FLA. Safest. More weight. Easiest to install / change out. Charges below 32F
- Factory built LiPo4 - 300-400% more $ than FLA. - 100-150% more $ than AGM. Not enough data to determine life expectancy/payoff. Requires a heating system and temperature cut off for charging. Less weight. Fast charging. Less generator time - 80% SOC is Ok
- Used EV lithium converted to 12V bank ??
-Other options?
Considerations:
-Other options?
