Exactly. So you charge enough that all cells are either fully charged or overcharged; the overcharged cells lose a small amount of water but otherwise remain fine and at 100% charge. There is thus a mechanism to keep them all fully charged and balanced.
If you balance so all strings get the same _current_ that would work; at that point each string gets the same charge, and is thus not much different than a single string in terms of life. But that's not how most balancers work, and it's hard to do.
However, again, you can't say "oh, that cell is at 2.35V so it's fully charged, any more charging and it will outgas." You can measure with a hydrometer (most accurate) or you can charge until you know it's at 100%. So traditional voltage balancing won't be as effective as it is for (say) lithium ion.
I wasn't thinking about keeping the voltage the same but more about actively shifting charge from cells that have reached the absorb voltage early and during absorb actively pushing extra charge into the cells which are staying at a lower voltage rather than letting the voltage rise in some cells to the point where they outgas. That is why I specified active balancing.
