Hi everyone. I have a wiring question which might be really easy to answer but still I need to be sure I'm doing the right thing. Before continuing, this is my setup
6 panels (260W each) have 2 lines of 3 in series and then both series in parallel
Midnite Solar SL 150 MPPT controller
48V 400Ah AMG battery bank - never let it go lower than 55% charge
2 100A DC brakers - one before the controller and one between the controller and batteries
Pure Sine Wave grid tied inverter - this inverter works as a UPS, when grid power is present it charges the batteries, when not it runs from them.
So I'm moving off grid now, I have the panels setup. My question is, what is the correct way to wire the controller to the battery bank and the inverter?
This is my plan so far:
Positive from controller to DC braker
Positive from inverter and battery bank to DC braker
Negative from controller and batteries to negative of inverter
I intend to turn of the grid power from the inverter, activating its UPS mode and run from batteries. Then, on cloudy days when the PV is not enough, I can turn on the grid power for the inverter or connect the generator to it and charge the batteries. I do not now if by doing this it will damage the midnite controller. What I believe will happen is that it will sense an increased in power "charge" and assume the battery is charged then stop charging them or adjust its output as necessary.
Please share your knowledge. Sorry if this is in the wrong area but is the one I saw more related to it. And if this was asked somewhere else, sorry but I couldn't find that post.
