It does not make any difference if it is Solar or AC charging. You do not control charging amps directly.
Look I know what you are asking for. Fact is unless you are willing to spend alot of money, you cannot have it, nor do you need it. You simply do not understand how a battery charges, or the physics that control it.
It is real simple. You control Charge Current by buying the AC charger with the current and voltage you want from what is available, and for Solar it is controlled by Panel Wattage with respect top controller capacity. It is a FIXED value. You do not control it. Example if you buy a 48 volt 15 amp charger, that is exactly what you get. That charger will charge at 15 amps until the battery voltage reaches the voltage set point in the charger.
Same for solar with a slight twist. Charge Current is determined by the available panel wattage and battery voltage. You do not control it. Example if you have 1000 watts and a 48 volt battery, assuming the controller is designed for it will have 1000 watts / 48 volts = 21 amps. If that is too much, you lower the panel wattage. If it is not not enough, you have to add more panel wattage.
It would be nice to have a Charger like you want. But it does not exist. As close as your going to get is a Hobby Charger made for Radio Control Planes, Helicopters, and Trucks. But there are some catches like the highest voltage is going to be 36 volts at the highest current around 40 amps. Those kind of chargers will charge a single cell AA battery at 1.5 volts @ 10 ma up to 36 volts @ 40 amps and everything in between. The second catch is you must have a DC Power Supply of the right voltage and current capacity. Example Revoletric make a Charger called PL8. It will charge any battery up to 8S LiPo or 33 volts @ 40 Amp. To use it to full capacity requires a 1400 watt DC power supply operating at 24 volts up to 50 amps. You are looking at $500 investment and still not have 48 volts.
However you are not going to find many if any AC chargers that will do 48/24/12 with both adjustable voltage set points and current control. Two reason. No demand for it, and it would be very expensive. You have sen it already. Example the Iota is a great charger and they make 1 flavor for 48 volt batteries fixed at 13 amps. Only thing you can adjust is the voltage to make adjustments from Gel to FLA. There is no current control, it is fixed at 13 amps. Can be used on as small as a 40 AH AGM up to 160 AH FLA and everything in between.
If your battery is so small it can only handle 5 amps of charge current, you do not buy a 10 amp charge. You buy a 5 amp or less. I think you keep get hung up on Marketing Terms and Sales Buz Phrases like 3-Stage and 4 STAGE.. Batteries do not need 3 or 4 stages. 3 and 4 stage chargers are OK if have all the time in the world and use an AC charger. It is not the best charging algorithm, just the most expensive, and not fast.
Optimum and most efficient battery charging is charging as fastest rate and highest voltage the manufacture recommends, , usually C/8 to C/6, with a Constant Current/Constant Voltage (CC/CV) until charging current tapers off to 3% of C, then terminate. So if that happens to be a Trojan 100 AH battery you want charge at 17 amps (C/6). to 14.83 volts until current tapers off to 3 amps, then terminate. Can you charge at a slower rate like C/12? Yes sir you can, it wil just take a lot longer and use more total energy. Go below C/12 and you risk never getting the battery fully charged.
The Elcon charger wil not do what you want. There is no charger to do what you want because there is no need for one. No one is going to make a charger that no one wants or can use. So why would you want to make charging painfully slow when there is nothing to gain?
But I will tell you what. For $2000 I will make you a battery charger that will charge up to 20 amps on 48 volt, up to 40 amps @ 24 volts, and 80 Amps on 12 volts. Real easy I go buy a 48 volt $300 Golf Cart Battery Charger, and add a circuit board to give you 24 and 12 volts at any voltage or current you want. You will have a 1 of a kind charger. You wil be able to charge as small as a 12 volt 1 AH battery up to a 48 volt 240 AH battery.
