I'm putting together a 24V 370Ah battery. Is there any disadvantage to using 2x 12V batteries which are physically larger than 4x 6V batteries?
More 6V batteries vs fewer 12V batteries
Which 12 volt 370 ah battery are you using? That would be a huge battery. 8D 12 volt batteries are only in the low 200 ah. range. There are lots of quality L-16, 6 volt, 370 ah. deep cycle batteries availableLast edited by littleharbor; 07-18-2017, 07:59 PM.2.2kw Suntech mono, Classic 200, NEW Trace SW4024 -
I agree with littleharbor. A 12v battery rated more than 200Ah will be very big and very heavy. Better to build a system using lower voltage high Ah rated batteries.
Since your system is only 24v @ 370Ah the 6v batteries would be a better solution.Comment
There is a reason they do not make many or any 12 volt 370 AH batteries. For Flooded Lead Acid battery they weigh roughly 60-lbs/Kwh.
Kwh = Battery Voltage x Amp Hour = 12 volts x 370 AH = 4.4 Kwh.
Weight = 4.4 x 60 pounds = 260 pounds.
A 6-Volt 370 AH battery weighs 130 pounds.
Ask you back and fingers, they know which one to use. So unless physical dimension restrict your choices use a light battery. That is why the make them in 2, 4, 6, and 8 volts. In my line of work we use a lot of 2 volt 4000 AH to 6000 AH batteries and those monster weigh 500 to 800 pounds each x 24 batteries for 48 volts. We use Gorillas from the zoo and these battery lifts and Baby Powder to do our work in case you are wondering.
