ok thanks. that answers my question. im the type that has to understand it, not just accept it for how it is. so thanks for the explanations.
so... i guess my next question has to do with all this.....
so to summarize...
im definitely replacing the batterry in the cabin. with what, i dont know. im in a slightly unique situation where i can get a "blemished" 31 group deep cycle from east penn for $115. from what i understand, im not going to beat that, right? i talked to the rep and he said they do get golf cart battery blems occasionally. if i can find a 100AH golf cart battery, would there be an advantage in getting 1 vs the other?
we need a 100w panel setup for a small shed which will be getting a 50ah battery. so... if we are doing that, im thinking i will pull the charge controller from the cabin and put it on the shed.
so... we will probably replace the charge controller with an mppt controller.
will the renogy one above work?
how many amps do i need for 200w?
is it ok to get one that can handle more to allow for expansion? or is oversizing mppt controllers bad?
should i rewire the panels to be in series instead of parallel, since the mppt can handle higher voltages?
thanks again folks.
so to summarize...
thanks again folks.
