Can't Decide on Small 12-volt or USB Power Packs
  • sherpa1d
    • Aug 2016
    I've had some ideas for a solar generator for the house but not quite ready to jump in yet. In the mean time I was thinking of a small portable kit to travel with MOSTLY for USB stuff. I have a small Pelican 1200 sitting around so I thought of getting an Allpowers 28-watt folding panel that would fit on the inside of the lid, then get 1 or 2 USB battery packs and run with it. I got to thinking about and relised that using USB battery packs really limits me to only USB stuff. I've found some small 12-volt batteries that would fit and leave some room in the case, I think the best so far is a 12-volt, 20 AmpH.
    I'm still learning about storage capacity and I do understand how to calculate the watts and such on the 12-volt battery. I however don't know how to on those USB batty packs. I'm trying to figure storge vs uses. I know the 12-volt will give me more options with a lighter adaptor but do 12-volts have the same storage capacity as the USB battery packs, I know they are different types of batteries. The battery pack I was looking at is 26800-mAH which if I'm correct converts to 26 AmpH but besides the out put volts of 5, I can't find any other data to calculate the watts to compair the 2.
    I know the 12-volt system will cost me more and include some work but like I said I'm planning on a bigger system in the future so I figure it would be some practice. I just want to make sure my storge capacity would make it worth while.
    A 12V 25Ah pack contains 300watt hours of power
    5V 50Ah pack contains 250watt hours of power.
    The 12V system could recharge a laptop via a 12V laptop adapter.
    BUT,
    your 28W panel will need how many hours in the sun to recharge a half empty pack ?
    ( hint 150watt hours / 25w of usable PV = 6 hours of sun, or about 2 days )
    • littleharbor
      • Jan 2016
      • 1998
      As to your usb needs you can buy charge controllers with usb outputs. Many of the recent offerings on ebay have this feature. usb cc.jpg
      • sherpa1d
        • Aug 2016
        Ok, cool. Guess I have some more math to work on, I looked over figuring out the solar panel to charge the battery part
          I would guess you would want about 75A to be able to recharge the battery in less than a day, Be sure you are getting an AGM battery and not a GEL battery, Almost the same, but the GEL battery can only accept a very slow charge rate and is not suited for solar
