Hi all,
We are in the process of relocating to our remote forest homestead. With all the possible last-minute costs (e.g. surprise $xxxx road repair), I'm trying to be as economical as possible now, then planning to update and upgrade in a few years once we get settled in.
The place was completely off-grid when the solar setup was installed by a previous owner. The panels are:
8 x Kyocera 62W 2 x Photowatt 105W
1 x Isofoton 150W
I know these are pretty well out of date and mismatched. I feel like the panels should be sorted when we have more time and money.
The charge controller is DIY (here is the inside):
The inverter is an apparently modified 3000W unit:
Batteries are 20 x Interstate U2200's, 6V golf cart batteries 232aH (this is showing up upside down in the forum... they are not upside down
So, long-term I think the right setup would be grid-tied with backup so we retain off-grid capability (100A grid power was run by a previous owner in order to get their mortgage). I am assuming a setup like that would take a whole lot more money than we can dedicate at this time. In the meantime, the batteries are far overdue for replacement. When we got here they took 22gal of distilled water, and are still turning the lights on, but the charge controller relays are clicking loudly every few minutes (apparently to prevent overcharging, detecting the high internal resistance I am guessing), so I need to turn the entire system off each night so we can sleep.
So as a short-term fix I'd like to replace the batteries at the very least. What would be a comparable AGM (or other alternative) setup that would get us by? Are any of the non-toxic saltwater and other more environmentally friendly batteries ready for primetime? The key here is it has to be a battery bank we can use with our current off-grid setup, then also with a future grid tied with backup setup.
If we have to replace either the charge controller or inverter or both, assuming we're not ready to invest in a full system upgrade, what would be comparable units that would get us by for now? I wouldn't feel bad having an extra off-grid setup on hand, as we could use it later on in our shop or elsewhere if/when we can afford the grid-tied-with-backup.
Thanks all!
1 x Isofoton 150W
Thanks all!
